Thread: Bass driver? |
| Posted on Thursday, November 25, 2004 - 10:08 pm: |
If my amp doesn't have a remote bass control, would it be a good investment to purchase a bass driver? would it act like a bass remote? |
NorthWest,
Michigan
Post Number: 5950 Registered: Dec-03
| Posted on Thursday, November 25, 2004 - 11:09 pm: |
the only thing that would really act as a bass level control like you want is a pre-amp with a bass frequency EQ setting, an EQ, or a remote attenuation circuit if you can find or build one that attenuates the RCA line level signal at the amplifer's input stage.
| Posted on Friday, November 26, 2004 - 10:19 am: |
is this what your talking about Glass? http://shop.store.yahoo.com/mobile-emotions/bacoreforany.html |
NorthWest,
Michigan
Post Number: 5958 Registered: Dec-03
| Posted on Friday, November 26, 2004 - 07:07 pm: |
exactly. it's an attenuator that goes inline with the amp. I just didn't have any specific links to one. thanks for the footwork.
Bronze Member Username: Jwbulger79
Florida
Post Number: 43 Registered: Nov-04
| Posted on Friday, November 26, 2004 - 07:37 pm: |
yeah, thanks dude. that's exactly what i have been looking for also. |
Bronze Member Username: Thumprms
Dalton USA
Post Number: 60 Registered: May-04
| Posted on Saturday, November 27, 2004 - 03:57 pm: |
no problem just happened to stumble across it, thanks glass i just ordered it, hope it helps |
Dalton USA
Post Number: 61 Registered: May-04
| Posted on Saturday, November 27, 2004 - 04:07 pm: |
Glass how would i go about hooking this attenuator up to my amp. Do i have to plug anything into the head unit? |
NorthWest,
Michigan
Post Number: 5987 Registered: Dec-03
| Posted on Saturday, November 27, 2004 - 07:53 pm: |
head unit -> RCA cables -> sub level controller -> RCA cables -> sub amplifier
Dalton USA
Post Number: 71 Registered: May-04
| Posted on Saturday, December 11, 2004 - 02:18 pm: |
all i get is some low bass noise when the hu is off. with the hu on the sub has bass but its very weak. the sub is barely hittin. i even turned the gain up on the amp and nothing. |
NorthWest,
Michigan
Post Number: 6256 Registered: Dec-03
| Posted on Saturday, December 11, 2004 - 05:31 pm: |
then something isn't wired right. may be a bad ground somewhere, also.
