Thread |
Last Poster |
Posts |
Pages |
Last Post |
  | Something went wrong after amp install | Anonymous | 1 | 1 | 2004-11-21 10:47 ET |
  | Amp for 4 10" subs | Jordan Athnos | 5 | 1 | 2004-11-19 10:09 ET |
  | Would This Amp Work | TheNewbie | 5 | 1 | 2004-11-19 10:01 ET |
  | Jeep GCH'99 amp installation | otabek rasulov | 11 | 1 | 2004-11-19 09:31 ET |
  | Need Input | BadAzzBowtie | 5 | 1 | 2004-11-19 09:27 ET |
  | How many amps dose a Generator put out? | BadAzzBowtie | 4 | 1 | 2004-11-19 09:17 ET |
  | How to hook up two amps | justin volker | 4 | 1 | 2004-11-19 08:44 ET |
  | 4 speakers to a 2 channel amp?.... | Ray G | 2 | 1 | 2004-11-19 00:52 ET |
  | Does anyboby have an opinion on 5 channel amps? | press1 | 2 | 1 | 2004-11-18 23:10 ET |
  | Y does everyone ignore my posts? WTF | Justin | 6 | 1 | 2004-11-18 22:25 ET |
  | What does MOSFET mean | Jonathan | 10 | 1 | 2004-11-18 22:12 ET |
  | Amp keeps blowing fuses | Dman7_9 | 4 | 1 | 2004-11-18 21:42 ET |
  | Hookin up my amp | Pimped_Escort | 16 | 1 | 2004-11-18 21:37 ET |
  | Good Amp | taylor17 | 2 | 1 | 2004-11-18 17:56 ET |
  | Need wiring/amp help | alex | 4 | 1 | 2004-11-18 15:41 ET |
  | Stuck on what amp to get...glass, john, anyone? | marshall white | 1 | 1 | 2004-11-18 15:38 ET |
  | What amp should i get? | Trigger Happy | 4 | 1 | 2004-11-18 14:47 ET |
  | Need amp help | Trigger Happy | 1 | 1 | 2004-11-18 14:45 ET |
  | Help with amp problems | Brian Olesen | 1 | 1 | 2004-11-18 13:02 ET |
  | What is the difference between Digital Amps and Others? | Eric Hughes | 4 | 1 | 2004-11-18 12:59 ET |
  | Need Help With Picking An Amp | GlassWolf | 5 | 1 | 2004-11-18 12:52 ET |
  | How are "cheater" amps rated in comps??? | GlassWolf | 2 | 1 | 2004-11-18 12:34 ET |
  | GlassWolf Or any one else with input. | GlassWolf | 5 | 1 | 2004-11-18 12:27 ET |
  | Amp question for 50's car for the allmighty Glasswolf | GlassWolf | 2 | 1 | 2004-11-18 12:21 ET |
  | Suggestion on AMP | Peter Ljubanovich | 1 | 1 | 2004-11-18 12:07 ET |
  | Are Coustic Amps any good? (ie - good value, not the worlds best am... | Anonymous | 15 | 1 | 2004-11-18 06:49 ET |
  | Good system for $700 | Damien Roberts | 11 | 1 | 2004-11-18 03:48 ET |
  | Whats a good amp for ... | Jon2682 | 1 | 1 | 2004-11-18 03:39 ET |
  | Amp kit | eric77 | 3 | 1 | 2004-11-18 02:44 ET |
  | Need opinions. Mcintosh or New Tube amp? | Eric Hughes | 5 | 1 | 2004-11-18 00:13 ET |
  | -Low end amp noise's, from head unit | Josh Smith | 4 | 1 | 2004-11-18 00:11 ET |
  | Square port or circle | derek moffett | 8 | 1 | 2004-11-17 23:42 ET |
  | Adding another amp need help | Isaac | 6 | 1 | 2004-11-17 23:06 ET |
  | Car audio amatuer seekin assistence | GlassWolf | 8 | 1 | 2004-11-17 22:07 ET |
  | Help please =) | GlassWolf | 5 | 1 | 2004-11-17 22:02 ET |
  | HPF, LPF, All Pass, which one is better? | GlassWolf | 3 | 1 | 2004-11-17 21:56 ET |
  | What do i set my XO at? | Daniel | 1 | 1 | 2004-11-17 21:22 ET |
  | Pioneer ts-wx20lpa | Brad004 | 2 | 1 | 2004-11-17 20:37 ET |
  | How to run 4 speakers and 1 sub to 500w amp. | trevore101 | 3 | 1 | 2004-11-17 17:16 ET |
  | Kicker kx300.2 | gabe vicara | 1 | 1 | 2004-11-17 15:55 ET |
  | Crossover on amp | dbomb | 3 | 1 | 2004-11-17 15:28 ET |
  | HELP!!!! Is this cadence amp any good????? glass, john, bacon | Anonymous | 5 | 1 | 2004-11-17 13:07 ET |
  | How is this for a starter set up | GlassWolf | 6 | 1 | 2004-11-17 12:58 ET |
  | Kicker XS 100 | marshall white | 7 | 1 | 2004-11-17 12:55 ET |
  | Which battery would supply more power | tafkam | 4 | 1 | 2004-11-17 12:54 ET |
  | 2ohm + 2ohm ?? | jonathan dickson | 3 | 1 | 2004-11-17 12:38 ET |
  | Amp for tempests | ghghghjkj | 1 | 1 | 2004-11-17 11:45 ET |
  | Good 600w x 2 amp? | Jordan Athnos | 3 | 1 | 2004-11-17 10:58 ET |
  | Infinity or audiobahn or another amp? | m B | 18 | 1 | 2004-11-23 18:22 ET |
  | Apline Type X /Amp | martyn | 9 | 1 | 2004-11-17 06:56 ET |
  | Remoting 2 amps | Damien Roberts | 4 | 1 | 2004-11-17 04:51 ET |
  | ? enough power or not | Damien Roberts | 2 | 1 | 2004-11-17 04:45 ET |
  | Bought amp, need help wiring details... | San Bas | 1 | 1 | 2004-11-17 00:04 ET |
  | Whats a good 4 channel amp? | San Bas | 6 | 1 | 2004-11-16 23:52 ET |
  | Rockford Fosgate Power 750s ? | Fosgate Monster Audi | 7 | 1 | 2004-11-16 23:43 ET |
  | How big of an amp do i need???? | Fosgate Monster Audi | 2 | 1 | 2004-11-16 23:39 ET |
  | Is a 2003 (not the new one) Rockford Fosgate 1001bd 1 ohm stable am... | Fosgate Monster Audi | 2 | 1 | 2004-11-16 23:37 ET |
  | How do i hook up two amps | Steve S. | 2 | 1 | 2004-11-16 22:44 ET |
  | S/N Ratio: Deciding Factor? | GlassWolf | 7 | 1 | 2004-11-16 20:38 ET |
  | Extra power | Anonymous | 10 | 1 | 2004-11-16 20:29 ET |
  | Amp gain needs to be set to max despite 4 volt preamp | GlassWolf | 23 | 1 | 2004-11-16 20:23 ET |
  | Bridging an amp | GlassWolf | 3 | 1 | 2004-11-16 20:18 ET |
  | Need info on Eclipse amp 3021 | GlassWolf | 2 | 1 | 2004-11-16 20:11 ET |
  | Ohm speaker and amp question | Hunter Warren | 2 | 1 | 2004-11-16 19:49 ET |
  | Amp | Sucubus | 2 | 1 | 2004-11-16 18:19 ET |
  | What would be a perfect amp for one 10" Brahma in a sealed box? | Alex Kintis | 4 | 1 | 2004-11-16 17:56 ET |
  | Jl Audio or Rockford Fosgate? | big don | 4 | 1 | 2004-11-16 13:09 ET |
  | Bridge amp to power front and back speakers | Isaac | 2 | 1 | 2004-11-16 11:42 ET |
  | What Kind Of Amp Do I Need | Isaac | 2 | 1 | 2004-11-16 11:36 ET |
  | Amp as Paralell??? bridge??? | Isaac | 2 | 1 | 2004-11-16 11:30 ET |
  | How much of an amp can a 70amp alt handle | Isaac | 2 | 1 | 2004-11-16 11:13 ET |
  | Simple amp question | marshall white | 3 | 1 | 2004-11-16 11:11 ET |
  | Adire Shiva...Push it with what??? | marshall white | 4 | 1 | 2004-11-16 11:00 ET |
  | What amp to use with 2 audiobahn immortals? | jon doe | 2 | 1 | 2004-11-16 00:46 ET |
  | Kicker or memphis amp for shiva | steve | 7 | 1 | 2004-11-16 00:41 ET |
  | Need 4 channel amp that can be bridged to two ohm mono! | Isaac | 5 | 1 | 2004-11-15 22:58 ET |
  | 2 jl w7's ...what amp?? | Joseph | 2 | 1 | 2004-11-15 22:44 ET |
  | What amps do i get??2x1100rms subs,+ 4 100 watt speakers | GlassWolf | 18 | 1 | 2004-11-15 22:21 ET |
  | Lights Flicker after installing a capacitor | GlassWolf | 2 | 1 | 2004-11-15 22:11 ET |
  | Amp Wiring? | Justin | 1 | 1 | 2004-11-15 21:33 ET |
  | What 4 12" subs and amplifer for under $600 | Anonymous | 1 | 1 | 2004-11-15 18:15 ET |
  | Amp for aw1251t audiobahns subs | gabe vicara | 3 | 1 | 2004-11-15 17:06 ET |
  | Jbl 1200.1 | Isaac | 8 | 1 | 2004-11-15 15:16 ET |
  | SPL Z1X-2400D | Sucubus | 2 | 1 | 2004-11-15 14:28 ET |
  | 1300 watts?? | Isaac | 2 | 1 | 2004-11-15 12:39 ET |
  | Kicker kx1200.1??? | GlassWolf | 3 | 1 | 2004-11-15 10:30 ET |
  | What kind of amp is best for me? | GlassWolf | 6 | 1 | 2004-11-15 10:27 ET |
  | Need Help With Picking Out A Amp | GlassWolf | 2 | 1 | 2004-11-15 10:19 ET |
  | Help needed on amp and sub set up!!! | lucas beckner | 2 | 1 | 2004-11-15 02:58 ET |
  | 4ga wire | lucas beckner | 7 | 1 | 2004-11-15 02:46 ET |
  | Old Hifonics ISIS question | Moorey | 4 | 1 | 2004-11-14 23:44 ET |
  | Old Hifonics ISIS question | press1 | 3 | 1 | 2004-11-14 23:34 ET |
  | BLITZ amps???????? | xxmdfmkxx | 6 | 1 | 2004-11-14 22:37 ET |
  | Amp to run 4 CVR 12s | GlassWolf | 3 | 1 | 2004-11-14 22:37 ET |
  | Distribution block? | GlassWolf | 2 | 1 | 2004-11-14 22:34 ET |
  | What is a subsonic filter???????? | GlassWolf | 3 | 1 | 2004-11-14 22:30 ET |
  | Hooking up Amp to stock deck. | Daniel Wright | 3 | 1 | 2004-11-14 22:25 ET |
  | How do you install an Amp? | shawn Corp | 3 | 1 | 2004-11-14 20:47 ET |
  | Suggested amp for 350w pioneer pair? | Ernesto Alvarez | 5 | 1 | 2004-11-14 16:53 ET |
  | Amp for 1 kicker s12L5. | lvloises305 | 3 | 1 | 2004-11-14 16:21 ET |
Closed: New threads not accepted on this page
