Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Pls help. which amp is good ?
Author Thread: Pls help. which amp is good ?
Username: Bassfreak596
Post Number: 21
somebody suggested me to go for the Eclipse sw8122dvc (1000w 500rms)sub.
but i dont know which amp will be good for it.
also will Eclipse sw9122(1500w 750rms) be a better option ?
will it make a big difference between the two ?
please suggest me with an amp which can run the 8122 and will not be too underpowered for the 9122 in case i ever buy that one.
i had thought of jbl bp600.1 / kicker kx 600.1
are these good enough ? anything other than this you can suggest ?
i know too many questions but
please help me.
Post Number: 22
hey why doesnt anyone answer my question ?
Username: Carguy
Post Number: 442
Hey Andy, SW9122 would be a better investment. Sure 500W rms sounds like a lot, but once you start pumping the music, you'll wish you had more power. If the price difference isn't much go with the higher power rating subs.
For the amp, Kicker 600.1 is a good choice. However, if your budget allows, go with 1200.1 model.
Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Pls help. which amp is good ? [ « Previous ] [ Next » ]
