Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Please Help!
Author Thread: Please Help!
David Terran
I wanted to know how to install a second amp, They Told Me that I have to run separate power cords, remote wire, and ground wire. I just wnt to make sure. I have two Fosgate 12' 100rms each Hooked to a Rockford Punch 250a2 amp. And i wanted to connect a mtx Road thunder 4022 To a Rockford 12' 350rms Bridged giving it 280rms Would this matter cause their not the same wattage. Thanks for myour help.
Username: Carguy
Post Number: 443
Hey David, depending on your existing power wires, you might have to either replace it with a lower gauge wire, add another power wire, or get a power distribution block.
If you have 4 gauge wire now, then you'll just need a distribution block. If for example you have 8 gauge, you'll be close to the border line.
If you have to wire a new power cable, get at least 8gauge.
For remote wire and ground, you can share with your current amp. If the ground wire is 8gauge, replace it with 4gauge and you'll be fine.
Don't forget to check your main fuse size. If it's 40A, you might want to get 60A.
Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Please Help! [ « Previous ] [ Next » ]
