Thread: How to run Alpine MRV-F357 on Max Power 14.4 Volt |
New member Username: Illusionaryman
Post Number: 1 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 06:28 pm: |
i have an Alpine MRV-F357 and iam wondering to know at what voltage my amp is running.. is it on 12.0V or 14.4V...how would i know?? if it's running on 12.0V then how can increase it to 14.4V to get more power out of the amp. according to the manual it says: power out put: RMS Continuous power (at 12.0V,20Hz to 20KHZ) Per channel into 4ohms (CH1-CH4)...30W. 0.08% THD Per channel into 2ohms (CH1-CH4)...40W. 0.03% THD Bridged into 4ohms (CH1-CH4).......80W 0.3% THD 4ohms (CH5)........................100W 0.3% THD power out put: RMS Continuous power (at 14.0V,20Hz to 20KHZ) Per channel into 4ohms (CH1-CH4)...50W. 0.08% THD Per channel into 2ohms (CH1-CH4)...60W. 0.03% THD Bridged into 4ohms (CH1-CH4).......120W 0.3% THD 4ohms (CH5)........................150W 0.3% THD MAX POWER (at 14.4V) Per channel into 4ohms (CH1-CH4)...90W Bridged into 4ohms (CH1-CH4).......240W 4ohms (CH5)........................300W thanx for any replys |
Sucubus Unregistered guest |
| Posted on Tuesday, November 23, 2004 - 07:03 pm: |
Most cars run about 13.7 or so at idle. you probably wont hear a lick of difference between 13.7 and 14.4 anyhow.
Silver Member Username: Carguy
Post Number: 380 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 08:34 pm: |
Hey I think those guys are on drugs. A .4V doesnot make an amp 2x stronger. If you read the manual carefully, they're trying to trick you. One is rms power and the other is peak (max) power. Ignore the peak crap. Use common sense, if a company made an amp that put out 2x more with only .4v difference, they'd be all over the news...
Post Number: 2 Registered: Nov-04
| Posted on Wednesday, November 24, 2004 - 03:44 am: |
thanx alot sucubus and Isaac for the reply
