Thread: What to get?!?!? |
New member Username: Champ0053
Post Number: 1 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 05:33 pm: |
I've been reading posts about what amps are good and not good.. well i want some opinion on an amp name and model are ALPHASONIK Q2150. is this any good. i currently have a 800 watt Thump T3006. which does the job. but doesn't push the bass the way it should.. so it's crap. and what about Clif model and MA model amp-s are these any good?!?!?! I'm looking to purchase an amp, but i'm on a cheap budget. or should i stay with the Thump amp until i can get something reasonable. thanks. |
Sucubus Unregistered guest |
| Posted on Tuesday, November 23, 2004 - 06:00 pm: |
Save your money up. Those brands are all about the same IMO |
Silver Member Username: Carguy
Post Number: 381 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 08:39 pm: |
Hey m B, have you tried MTX 6500D? It costs around $80 used but it puts out 500W rms at 2ohms and 775W at 14.4V. I personally have tested MTX amp and they under rate their amps. With the optional remote bass control, I bet it'll more than drive your subs to the max. If you want/need more power, Audiobahn 2300HCT is a very nice model. |
Post Number: 3 Registered: Nov-04
| Posted on Wednesday, November 24, 2004 - 04:41 pm: |
Hey Isaac you have any idea where i can get it at that price used... i looked on e-bay one ad is up... but it includes a sub with the amp.. which i don't need, cause i want to drive 2 10" subs, in my custom made fiberglass speaker holder(box). i'll send you pictures of it when it's finished.. you can give your opinion on it, if you like.. cause i'm looking to manufacture them. maybe i can wait a bit and see if any other mtx amp comes up, cause that is a price i'm looking for. thanks for the info bud. |
Post Number: 419 Registered: Nov-04
| Posted on Wednesday, November 24, 2004 - 05:11 pm: |
Hey m B, I was bidding on one of the MTX 6500D last week. It started at $1 and ended around $80. I didn't need it but when I submitted my bid it was around $30. I'll let you know if I find it again.
