Thread: NEED HELP!!! |
Bronze Member Username: Counterstrike
Post Number: 14 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 10:40 am: |
what kind of amp would i need if i bought 4 Alpine SWR-1521D 15" Dual 2-ohm Voice Coil Component Subwoofer?? thanks for all the help |
New member Username: Stumped
Post Number: 6 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 10:45 am: |
wire them parallel to make the output a 2 ohm load. so look for an amp that pumps 1200-2000 watts @ 2ohms since the subs are 200-500 watts rms |
Post Number: 15 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 10:59 am: |
what brands do you recommend? |
Post Number: 16 Registered: Nov-04
and what type of amp 2 channel, mono, multi ?? |
Silver Member Username: Carguy
Post Number: 348 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 11:27 am: |
Hey Counterstrike, for subs, class D mono will work just fine. The brands you can look at are Rockford/Kicker/JL/Audiobahn 4125HCT or 2300HCT/MTX/MA Audio. Always look for sub amps with remote bass control. You won't regret it! |
Post Number: 9 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 11:51 am: |
i would automatically think a 2 channel amp..but i hear its better output power wise to go with a mono amp. i would go with jl audio,kicker,hifonics |
