Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Amp questions?
Author Thread: Amp questions?
Username: Martscorsa
Manchester
England
Post Number: 11
mrp-m350 amplificateur mono 350wx 1rms 2ohm, 14.4v 700w max conception circuit class D v-power Can i power 2 1000w jbl subs with this amp?
Username: Carguy
Post Number: 353
Hey Martyn, if that amp's 700W is rms power, then yes you can power 2 1000W subs. However if it's peak power rating, then you won't be able to maximize your listening enjoyment.
Manchester
England
Post Number: 12
what am i best doing isaac buyin a new amp if i do how will i hook it up? thanks pal
Username: Carguy
Post Number: 366
Hey Martyn, it'll depend on the amp. If the amp you have is 700W rms at 14.4v, then it's good enough. If it's just a peak, and you have cash, a stronger amp will definitely produce much desired result.
Look for a 1 ohm stable amp since you have 2 subs. That way you can connect the subs in parallel mode (pos to pos and neg to get on each speaker, then joining all the pos together and all the negs together for 1 ohms).
Oh another thing, look for amps with remote bass control. It is very very handy. I use it all the time.
Manchester
England
Post Number: 13
k thanks isaac ill let you know what i do on payday cheers pal
Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Amp questions? [ « Previous ] [ Next » ]
