Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Distribution blocks...? keep the fuse...
Author Thread: Distribution blocks...? keep the fuse under the car...?
Username: Djzavala
Whittier, Ca
Post Number: 99
Im adding a distribution block because im adding a second amp, but i dont know if i still have to keep the fuse under the hood (close to the battery), or if i have to take it off? thanks
Help2
The fuse under the hood is to prevent a fire
due to an accident or poor wiring...
A distrobution block, fused or not, does not
take the place of the fuse under the hood.
Username: Djzavala
Whittier, Ca
Post Number: 100
ok, thanks, so ill leave it alone, now i have this question, can i use regular speaker wire (16 gauge) as remote wire? Im a start a thread on this but if you can help thatd be great.
Help2
You can if its youve got some to waste
but any 18 gauge wire till work.
Most install shops will give it to you
for free, or real cheap if you ask.
Help2
Username: Djzavala
Whittier, Ca
Post Number: 102
ok thanks
Username: Carguy
Post Number: 357
FYI, HU puts out 200ma to the remote wire. So you can use almost any wires.
Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Distribution blocks...? keep the fuse... [ « Previous ] [ Next » ]
