Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Install kits
Author Thread: Install kits
Username: Ealvarez
Post Number: 7
ok i bought a 600 watt kenwood KAC-7285 amp to go with my 2 350w pioneer subs. just wondering with the install kits, will it hurt if i get like a 800 or 1000 watt kit? should add alittle flexibility if i upgrade my system in the future. might get a 750 or 800 watt pioneer amp in the future.
Username: Carguy
Post Number: 321
You can't hurt anything by getting stronger power wire except your wallet. FYI, Pioneer/Kenwood amps aren't the best for your money.
Oh do make sure your alternator can handle that much power.
Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Install kits [ « Previous ] [ Next » ]
