Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Setting Gains
Author Thread: Setting Gains
Username: Mr_kebo
Albertville, Al
Post Number: 15
I remeber seeing someone post a link aboput setting gains and help on that but i cant find it now, i tried searching but no luck. Anyone have that link they could share
Username: Carguy
Post Number: 313
I'll just give you a brief explanation on it. The purpose of the gain control is to match HU's output voltage with the amp's input sensitivity. So if your HU says it's 4v, then set the gain to 4v or close to it.
Username: Mr_kebo
Albertville, Al
Post Number: 16
Well im bout to purchase a DEH-P9600MP and the voltage of that is 6.5 volts. SO i just match that with my amp?
Username: Carguy
Post Number: 330
If that is the HU's output voltage then yes. You turn the gain to somewhere around 6v. Doesn't have to be exact. You can operate the amp even at 5v without much problem.
On my amps, I have it 1v less than the HU's.
Username: Mr_kebo
Albertville, Al
Post Number: 18
ok thx
Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > Setting Gains [ « Previous ] [ Next » ]
