Thread: Amp wiring to sub...basic question |
Chris Spencer Unregistered guest |
| Posted on Monday, November 22, 2004 - 08:23 am: |
hi all, relatively new to all this, starting off with sum really cheap equipment but just a quick wiring question. I have an SPLX amp and sub but how do i wire the sub to the amp for best bass? the amp has 4 outputs (L+,L-,R+ and R-) which two do i use for my sub or can i combine them somehow for better sound? Please any helps appreciated... Cheers people |
Bronze Member Username: Jlprix91
West,
Michigan
Usa
Post Number: 28 Registered: Oct-04
| Posted on Monday, November 22, 2004 - 10:11 am: |
it depends on the rms of your sub, you dont want to bridge the amp if your sub cant handle the power |
nnnnick b. Unregistered guest |
| Posted on Monday, November 22, 2004 - 10:59 am: |
If the sub is a single voice coil driver then hook the L- and the R+ up to the sub(This is called bridging, only do it if the amplifier is bridgable and if the amp can handle the electrical load of the sub, ohms) If the amp is a dual voice coil driver then wire one voice coil to the L and one to the R. |
| Posted on Tuesday, November 23, 2004 - 07:27 pm: |
its an splx 400 watt sub i think with a 350watt splx sub. was bought as a package i believe...not sure whether its single voice?? Really am new to to this! want some bass tho! Thanks people
| Posted on Tuesday, November 23, 2004 - 07:29 pm: |
o the sub has two wires coming out of it....one marked postive(red) one negative(black) if that helps |
New member Username: Chrismjspencer
Cambs, UK,
UK
UK
Post Number: 1 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 07:33 pm: |
hi i've even registered as a member now! great discussion board, even tho i feel a million miles awy from you US lot! Chris |
Sucubus Unregistered guest |
| Posted on Tuesday, November 23, 2004 - 07:38 pm: |
Do what nnnick b. said for the single voice coil sub Its a SVC sub, about 99% chance its 4 ohm Id be willing to bet that amp is bridgable too. |
Cambs, UK,
UK
UK
Post Number: 2 Registered: Nov-04
| Posted on Wednesday, November 24, 2004 - 07:53 am: |
alright thanks people, done that and it sounds good! I think the amp is bridgeable as the terminals are marked "crossovers" :-) |
