Thread: Glasswolf Please Help! |
Freddy P Unregistered guest |
| Posted on Sunday, November 21, 2004 - 04:52 pm: |
I have a older kenwood KEC-202 Electronic Crossover I Am Really not sure where to set it at I Has 30 To 800hz. They Told me that for the sub it has to be lower than50hz. Iam running A Diamond Audio Sub And A Mtx Thunder 4202 amp Bridged Putting Out 280 to the sub. Also I have a question about the amp when im playing it it seems like the little red light from the amp comes and goes when the sub is hitting. Almost as if it was moving to the beats. I would apreciate your help |
Silver Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 104 Registered: Oct-04
| Posted on Sunday, November 21, 2004 - 09:13 pm: |
The setting on the crossover depends on what kind of music you listen to and your personal taste, but I wouldn't go over 90Hz. As far as the light blinking on your amp, make sure all of youre power connections are good. Check at the battery, power wire, fuse holder, terminals, and ground. You vehicle should be able to handle that small of an amp. |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 175 Registered: Jun-04
| Posted on Monday, November 22, 2004 - 12:30 pm: |
Freddy, 50hz is to low. Try setting it around 80hz. Start there and play around in that area till you find something you like. |
| Posted on Monday, November 22, 2004 - 04:55 pm: |
Thanks guys i got the system right were i want it. Also If any of you guys know about cars Do You know if i can cut the whole firewall in the back by the seats I was thinkin of Customizing some subs in the back. |
Silver Member Username: Carguy
Post Number: 322 Registered: Nov-04
| Posted on Monday, November 22, 2004 - 04:59 pm: |
Anything is possible... Some people take out the whole back seat and put in custom piece. |
Post Number: 323 Registered: Nov-04
| Posted on Monday, November 22, 2004 - 05:00 pm: |
Hey Freddy P, I hope you're not that guy on eBay. He took my money and never sent the product. He's delisted now. FYI, his name was also Freddy P.
| Posted on Monday, November 22, 2004 - 08:51 pm: |
What's the firewall for really. I think Is Just So it Could hold the back seat on older cars Isn't it. But Nothing would go wrong with my car if i do cut it right? By the way Isaac I'm Not the guy on ebay, I dont have a credit card and i'm only 17. But I heard in the news Like a week that they arrested like 6 people For selling bogus stuff on ebay and the customers never got there merchandise. Maybe you were one of those customers that never got their stuff. |
Tulsa,
Ok
Usa
Post Number: 108 Registered: Oct-04
| Posted on Monday, November 22, 2004 - 09:45 pm: |
Rear firewall? Between the cab and trunk? Take that batch out and make a wall of woofers. It only holds the seat in. |
Post Number: 332 Registered: Nov-04
| Posted on Monday, November 22, 2004 - 09:48 pm: |
Hey Freddy, glad you weren't that crook. Anyways, when you say firewall, you're not talking about the firewall under your dashboard right? That one you don't want to cut. It's there to protect you in case of fire. The seats are up to you. You can cut/replace if you like as long as you own the car. I've seen people drill a big hole on the back seats to install 12" subs, then protect them with a grill. If done right, it looks good. The back passengers won't thank you much though. |
| Posted on Tuesday, November 23, 2004 - 02:49 am: |
Yeah I was talking about the rear I m going to try to fit in at least three twelves, or do you guys think i should get 2 15's , I need to measure everything first. I was thinking about going with Rockford fosgate I saw some that were 600rms a each. |
| Posted on Tuesday, November 23, 2004 - 02:50 am: |
Post Number: 345 Registered: Nov-04
| Posted on Tuesday, November 23, 2004 - 09:45 am: |
Hey Freddy, why stop at 600W rms subs? If you have the cash, go with 1000W rms 15" subs. I find that 15" - 18" subs pound much stronger and produce lower bass. I'd personally get 2 15" or 18" subs. You'll find that it's much easier to configure 2 subs than 3. Most amps support 4,2, or 1 ohms. With 3, you'll have odd number, which won't maximize the amp's power. Also look for subs with heavy magnets. I think mine's 320oz. The heavier the magnet, the more it'll pound your car! |
