Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > LiforniaAmp blowing fuses
Author Thread: LiforniaAmp blowing fuses
Username: Dontavious89
Laurens, SC
Post Number: 46
I have a Profile California 1000 watt amplifier,I was listening to some music then all of a sudden my amp cut off.My inline power fuse was not blow,but the two on my amp were.I tried to put a new one in,Sparks flew,there goes 3.00 more $'s.I checked my subwoofer connections ,theres no external bad connections.What is wrong?What can I do?Help!
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 103
Maybe your overloading the amp. How do you have your speakers wired? How much of a load(ohms) are you putting on the amp? Can the amp handle it? Check your ground wire to the amp.
Laurens, SC
Post Number: 47
I have a dual 4 ohm voice coil subwoofer.I have one channel to each coil.I don't know if it's too much,but it sounds the best that way.Is this a bad idea?How would the ground affect my amp?
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 106
Is your amp bridgable to 2 ohm? If it is then bridge it. I heard that if you have a bad ground connection then you can blow fuses. Check the ground connection and amke sure that it is tight.
Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > LiforniaAmp blowing fuses [ « Previous ] [ Next » ]
