Thread: Amp not getting power |
larkincs Unregistered guest |
| Posted on Sunday, November 21, 2004 - 11:25 am: |
I have connect the power wire to the battery and i have grounded it .. i have connected the rca cables and remote to the back of the headunit i have a pyramid legacy 1030 and 2 pioneer 10" subs please help any stuff i can try |
Bronze Member Username: 54danny54
Post Number: 46 Registered: Nov-04
| Posted on Sunday, November 21, 2004 - 12:00 pm: |
did u turn the car on lol |
New member Username: Emk
NH
Post Number: 2 Registered: Nov-04
| Posted on Sunday, November 21, 2004 - 06:03 pm: |
does it have a remote turn on cable that u hook directly to the head unit... i had this problem and i hooked the remote wire to the wrong wire on the head unit.... or maybe its a grounding problem... make sure its touching as much metal as possible. I tried to ground my amp and there is a glossy coating on the floor of my car under the carpet, i had to scrap this away to get a good connection |
Bronze Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 100 Registered: Oct-04
| Posted on Sunday, November 21, 2004 - 08:59 pm: |
Try jumping the + terminal of the amp to the remote terminal. If it turns on then u used the wrong remote wire on your deck. If it doesn't turn on then you may not have power to the amp or worse(a bad amp). |
