Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Equalizer rca
Author Thread: Equalizer rca
Username: Munkyjojo
Winamac, Indiana
Post Number: 58
i have an alpine equalizer. my problem is that everything is done with rcas. the input, speaker output and subwoofer. my queston is, what can i do about turning the speaker output rcas into regular speaker wire? also, there is only one set of rca's for rear, and another for front. its just that I only have a stock alternator so i dont want add another amp for my speakers.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5921
the EQ is pre-amp only.
you need amplifiers for all channels used.
Username: Carguy
Post Number: 426
You can buy a low powered amps that'll work within your stock alternator's limit. It'll still sound a lot better than your HU.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5941
a JBL P80.4 would do the job at 40wRMS x 4 @ 4 ohms
pretty cheap, reliable amp for 4 channel use.
Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Equalizer rca [ « Previous ] [ Next » ]
