Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > URGENT HELP
Author Thread: URGENT HELP
hey guys, im helping a friend with his SUV, FORD ESCAPE to be more exact, well here's the thing
we want to install an amp for a subwoofer but he does not want to remove his stock radio nor connect a "pre-amp"...how do i connect the amp 4 the subs and what do i need?? what problems can i encounter?
e-mail me if anything thnx
JRE
one more question the sub is a auidbahn 450 rmx, what amp can i use?
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 87
Not to many options w/o a pre-out converter. you could get an amp with high inputs and wire it from the back speakers. Probably won't sound too good though.
JRE
u recomend a pre-amp?
usign a BTL?
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 89
Yes a pre amp is the best way to go w/o replacing the stock radio.
JRE
one more thign
what amp do u guys recomend
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 91
That depends on the sub, how loud you want, your taste, and price range.
Home > Message Board > Car Audio > Amplifiers > Archive through November 26, 2004 > URGENT HELP [ « Previous ] [ Next » ]
