Home > Message Board > Car Audio > Multimedia Systems > Archive through March 19, 2006 > PIONEER AVH-P6600DVD for Multizone???
Author Thread: PIONEER AVH-P6600DVD for Multizone???
I have a PIONEER AVH-P6600DVD for my car, I would like to know if there is someone who has the code to use it Multizone?
Thanks a lot!!
Username: Dropthedeuce06
what is multizone and how do you liek the screen? i think im going to buy one...
Username: Shouder
Wisconsin
Post Number: 70
Do you mean dual zone. do you have a second screen? and a second source hooked up in the a/v inputs? If you do just engage dual-zone and watch one in back and the other up front. No code needed, just read the instructions.
AussieRob
I think by multizone he means, how do you make it read different region DVD discs. eg, Region 1, 2, 3, 4 etc...from different countries.
I too want to know if there is a code or hack to let it play multi region DVD discs...
Anyone know?
Username: Shouder
Wisconsin
Post Number: 75
Ok, i think you an me are talking about two different things. Your talking about region free dvd players. And im not sure if incar dvd players are region free. Im talking about dual zone, or multizone audio sources so you can watch or play, multiple things at one time on different screens.
VictorDias
I hava a PIONEER AVH-P6600DVD also and I want to know if there is any way I can make it read different region DVD disk? anybody knows how?
VictorDias
Has anyone got an answer to making the AVH-P6600DVD region free & allowing you to play DVDs whilst moving?
To get the DVD to play while the vehicle is in motion, simply connect the light green wire that the installation manual instructs you to splice into the power supply (12 volts)of the parking brake to a switched power supply (terminal controlled by ignition)which will in turn tell the unit that the parking brake has been activated and the dvd is ok to play.
Folks, scratch what I said above about hooking up the green wire to the switched power supply. It is safer to hook it up straight to a grounding location. Simple and safe.
widowmaker
did any one find a hack for pioneer avh p6600?
Not Entered
Did anyone find the hack for playing multi region discs???
the pioneer avh p6600 dvd is reqion locked.. the only way to make it multi region is to buy the multi region unit - the pioneer avh p6650 dvd. It's the Asian market model and is completely region free. As mentioned above all you need to do r.e. watching dvds on the move is ground the light green wire.
Home > Message Board > Car Audio > Multimedia Systems > Archive through March 19, 2006 > PIONEER AVH-P6600DVD for Multizone??? [ « Previous ] [ Next » ]
