Thread: DVC or SVC? |
Bronze Member Username: Kwdnls
Post Number: 12 Registered: Sep-04
| Posted on Friday, November 19, 2004 - 01:22 am: |
I have a 2 channel amp rated at 750 RMS. The subs I am looking at are both rated 400 RMS and 800 peak. The SVC are 4 ohm ane the DVC are 2 ohm. I want to get the most power out of my amp so I will be wiring the subs at 2 ohm. In this case, which is the better sub to get and which is the best overall? |
Bronze Member Username: Jlprix91
West,
Michigan
Usa
Post Number: 25 Registered: Oct-04
| Posted on Friday, November 19, 2004 - 08:46 am: |
you could go with eiter svc or dvc on this one because your ohms match, when you wire to svc's 4 ohms parralell you get a 2 ohm load. on the other hand the dvc 2 ohm in a series are also a two ohm load. the dvc are a little bit more versatile so you could go with a higher rms or a lower price |
Post Number: 13 Registered: Sep-04
| Posted on Friday, November 19, 2004 - 01:46 pm: |
How do you wire parralell? |
Silver Member Username: Deathshadow
Post Number: 262 Registered: Oct-04
| Posted on Friday, November 19, 2004 - 02:02 pm: |
You wire coils pos to pos & neg to neg then to the amp. |
Post Number: 14 Registered: Sep-04
| Posted on Friday, November 19, 2004 - 02:16 pm: |
So you basically connect the subs together first and then hook them to amp? What about if I only have one speaker? And what is wiring in series? |
Post Number: 264 Registered: Oct-04
| Posted on Friday, November 19, 2004 - 03:15 pm: |
Wiring in series you connect pos to neg and depending on the sub type and ohm load you wish to accomplish would determine how you do this in conjunction with a parallel connection to the amp. What would your "one speaker" be? DVC, or SVC? 2 or 4 ohm? |
Post Number: 16 Registered: Sep-04
| Posted on Friday, November 19, 2004 - 07:16 pm: |
The one speaker is SVC and 4 ohm. And I would connect pos to of neg of what? Sub and amp or sub to sub? |
Post Number: 17 Registered: Sep-04
| Posted on Monday, November 22, 2004 - 01:05 am: |
hello? |
nnnnick b. Unregistered guest |
| Posted on Monday, November 22, 2004 - 11:21 am: |
if u only have one sub then u can bridge the amp into it. Connect the sub to the L - and the R + on your amp. |
Post Number: 21 Registered: Sep-04
| Posted on Monday, November 22, 2004 - 12:18 pm: |
But would that put the entire 750 into that speaker? |
