Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Amp for 4 10" subs
Author Thread: Amp for 4 10" subs
j brower
my original thread is in the archive for nov 14.
I got my subs hooked up in my box. When the speakers play over 30, they seem like to much air is inside, and they blow out with horrible sound. Should I add some insulation inside? Any thoughts? Thanks, Jeff
Username: Southernrebel
Monroe, Louisiana
Post Number: 272
what do you mean?
do the subs make a "huffing" sound?
Is the box sealed or ported?
what type of subs are these and what amp do you have?
j brower
all of the info is in the original thread in the archive but here it is.
the magnum mtx subs have an impedance of 4 ohm. They have a 125 watt rms and 250 watt total.
dhd lcd 9444 1000watt amp
max power@ 2 ohm : 250w x 4 =1000w
box is sealed.
Username: Jroc
West Salem, Wisconsin
U.S.
Post Number: 24
get a 1 ohm stable amp and parallel it all it will be at one ohm mono just make sure your not gonna push the subs way over max.
Username: Jroc
U.S.
Post Number: 25
actually no it wont..it will be at 2 ohms which is still fine
Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Amp for 4 10" subs [ « Previous ] [ Next » ]
