Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > How are "cheater" amps rated in comps...
Author Thread: How are "cheater" amps rated in comps???
what_tha
I recently read a post on the USACi message board that said some of the well known "cheater" amps will be rated differently in comps.
Here is what it said:
Rerated:
----- Cadence Z7 300 watts
----- Mark Antony 25 OPCM 350 Watts
----- Ma Audio HK4000d 1000 Watts
----- Atomic (all models) Unlimited Watts
this is not what the amps are rated at. i mean the cadence z7000 is rated at 50wrms @ 4ohm.
i was wondering if a kicker xs100 would be "rerated" in comps???
Username: Glasswolf
NorthWest, Michigan
Post Number: 5890
for a long time, circuits like IASCA and USACi rated power classes as combined total power of amplifiers as per manufacturer rated power @ 4 ohms.
thus an Orion 225HCCA is rated as a 50 watt amp (25x2) when in reality it's half-ohm stable, and can produce up to 400 watts.
Since the average amp is only 2 ohm stable, this gave users of the high current amps an unfair advantage in power classes if SPL was a factor in scores.
USAC is just trying to level the playing field finally to eliminate unfair power class ratings.
In all honesty, I feel they should judge power classes on actual power based on either current draw, or amplifier load, but these are both difficult to measure accurately, and leave much room for cheating by dishonest competitors.
Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > How are "cheater" amps rated in comps... [ « Previous ] [ Next » ]
