Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Amp kit
Author Thread: Amp kit
daniel james mcdoogle
is there a big difference between the performance of an expensive amp kit compared to a cheap one. they have decent looking ones at meijer for 25 bucks, how bad would they be.
Username: Bigap15
Post Number: 46
I wouldnt get it. It is probably an 8 gauge kit. You can get a 4 gauge kit here:
http://www.knukonceptz.com/productDetail.cfm?prodID=KOLAK4
This is probably the best priced 4 gauge kit.
eric77
If I were to get a 1500w amp in a jeep grand cherokee would I need to run 0 guage wire?
Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Amp kit [ « Previous ] [ Next » ]
