Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > How to hook up two amps
Author Thread: How to hook up two amps
Username: Legacy
i got two 12 legacy subs each can hold 2000 watts of power. right now they are powered by a 1800 watt legacy amp i got another amp same kind. i want one amp to power one sub and the other amp to power the other sub. how can i do this and what do i need to hook it up
Username: Fosgatemonsterz
San Lorenzo, California
Post Number: 29
Get a fused distributive block. Then run 4Gauge into the distributive block, and you can either run a 4 gauge out or a 8 gauge out to the amp. Make sure that the same gauge wire you use to power the amps, is the same gauge as the wire to ground the amp. Hope I Helped. :-D
Username: Deathshadow
Post Number: 236
um... not sure if that’s peak power or not but if its a combined RMS of 3,600 watts using the two amps 4 gauge cable will definitely NOT cut it to well; go down to 0/1.
Username: Legacy
thanks also if i get another battery to put in my trunk how would i hook it up so everything will come on when i turn the key
Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > How to hook up two amps [ « Previous ] [ Next » ]
