Thread: Adding another amp need help |
New member Username: Smitty64
United States
Post Number: 4 Registered: Nov-04
| Posted on Tuesday, November 16, 2004 - 01:27 pm: |
hey is there any way to hook up two amps? and if i did hook up two amps would i need a strike cap (compasator)? thank you, Kyle |
Silver Member Username: Carguy
Post Number: 245 Registered: Nov-04
| Posted on Tuesday, November 16, 2004 - 01:33 pm: |
Hey Kyle, that'll depend on the 2nd amp's power. Your stock alternator can handle only so much power. If they both total around 450W rms, then it should be okay. Adding a capacitor will give you a tight bass and less light flickerings. Just make sure you have good ground for the amps.
United States
Post Number: 5 Registered: Nov-04
| Posted on Wednesday, November 17, 2004 - 10:57 am: |
k thanxs i will have more questions later or should i just get a 400W amp and also hook up my 200W amp??? |
Bronze Member Username: Crazy3rdgen
Long Neck,
Delaware
U.s
Post Number: 40 Registered: Sep-04
| Posted on Wednesday, November 17, 2004 - 06:38 pm: |
do the amps always have to be the same brand for example.. i hook up 1 brahma 12 to a jbl 1200.1 and also a rf1001bd for 1 vr comp 15" 500w at 4 ohms would this work? 2 diff kinda amps |
Post Number: 263 Registered: Nov-04
| Posted on Wednesday, November 17, 2004 - 11:05 pm: |
No Sean, the amps can be any brand you like. As long as you have enough power for them, you're fine. |
Post Number: 264 Registered: Nov-04
| Posted on Wednesday, November 17, 2004 - 11:06 pm: |
Hey Kyle, as long as you don't plan on maxing out the amps, you should be okay.
