Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Bridging an amp
Author Thread: Bridging an amp
I have a 1600 watt peak amplifier with 4 channels
2 channels indicated as front speakers and 2 channels as rear. how would i bridge the four of them together to make 2 channels at 4ohms
Username: Carguy
Post Number: 246
Hey Robert, normally in 4 channel amp, channels 1 and 2 gets bridged to 3 and 4. You should check your manual. It should also be labeled on the speaker terminals or at the bottom of the amp case.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5838
yeah please check the amp manual
usually there is a switch or button to enable bridged mode. then you use a specified pair of wires from the bridged channels to run the speakers.
Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Bridging an amp [ « Previous ] [ Next » ]
