Thread: Extra power |
| Posted on Tuesday, November 16, 2004 - 10:23 am: |
I was wondering if it was possible to have an extra battery in the trunk to power only the amps. When my subs hit the lights dim. So is it possible or should i just get a new alternator and capacitor? Thank you |
Silver Member Username: Carguy
Post Number: 236 Registered: Nov-04
| Posted on Tuesday, November 16, 2004 - 10:47 am: |
Extra battery in the trunk won't help at all. Depending on your stock alternator size and amp, you might be able to get by with just a capacitor. Try this formula, 12V x 65A (for older cars and 75A for current cars) = 900W. If your amp is below that power range minus heater/headlights/radio etc, then a cap might do the trick. |
Silver Member Username: Deathshadow
Post Number: 226 Registered: Oct-04
| Posted on Tuesday, November 16, 2004 - 12:26 pm: |
When the car is off yes but I find most new cars now (the ones I deal with) produce 14V + when they are running and warmed up. |
Post Number: 227 Registered: Oct-04
| Posted on Tuesday, November 16, 2004 - 12:29 pm: |
Mine actually is on the high side; I read 14.5 - .7 volts with the car on @ idle and 13.1 with the car off (real good battery I guess). |
Bronze Member Username: Thrust
Post Number: 61 Registered: Nov-04
| Posted on Tuesday, November 16, 2004 - 02:22 pm: |
First I'd put a cap in there and see what happens with the lights. The setup you described creates more of a load on the alternator. Plus you'd need a multi-battery isolater. You really only need extra batteries if you listen to your stereo with the car off. Best option is to buy a high output alternator. |
| Posted on Tuesday, November 16, 2004 - 02:51 pm: |
Okay thanks for the info. Now what kind of alternator and capacitor do u reccomend? How about car audio batteries like optima? |
Wangbar Unregistered guest |
| Posted on Tuesday, November 16, 2004 - 02:56 pm: |
You only need an isolator if you run your stereo with the car off. adding a second battery is better than a cap IMO. |
Post Number: 249 Registered: Nov-04
| Posted on Tuesday, November 16, 2004 - 03:36 pm: |
Hey wangbar, 2nd battery is not always better than a capacitor. If lights are dimming slightly, a cap will fix it, where else 2nd battery probably won't help much. Glasswolf has an article on capacitor, it's worth reading. The alternator I bought mine from was 4alterstart.com. They should have one that fits your car. I found them cheaper than others. If you're going to get HO alternator get something around 170A or higher. That way you're covered for the future too. You can buy 1F capacitor from most manufacturers. They produce them using similar technology so you should be fine. Just get fooled into buying 50F or larger, you don't need it that big. Remember it's 1F per 1000W of peak power. |
NorthWest,
Michigan
Post Number: 5837 Registered: Dec-03
| Posted on Tuesday, November 16, 2004 - 08:16 pm: |
http://www.wickedcases.com/caraudio/capacitors.html http://www.wickedcases.com/caraudio/charging.html there ya go
| Posted on Tuesday, November 16, 2004 - 08:29 pm: |
Great articles glasswolf they really cleared up a lot for me |
