Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Remoting 2 amps
Author Thread: Remoting 2 amps
Username: 2muchbang4um
I got a pyle 1600 wt and a pyramid 800 wt and I hooked them up but I can't remote both of them, because when I do they both end up staying on. Can someone please help me!
Username: Hurleyblink187
Post Number: 16
what do you mean by remote? the remote on/off switch wire? well if that is you question just splice the on going to the amp and put it into the other amp
I did but when I do that both of the amps stay on constantly.
Username: Deathshadow
Post Number: 235
You need to try a dif remote wire power source then.
Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Remoting 2 amps [ « Previous ] [ Next » ]
