Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Square port or circle
Author Thread: Square port or circle
Username: Kickerlover88
Norman, Oklahom
ok, i have a square sub, its a kicker solobaric, do i need to have a square or (slot) port? or can i just have a regular old circle port? someone please help!
thanks
Help2
Doesnt matter.
Port area is port area
Norman, Oklahom
are you absolutely positive help2? i need a confirmation, i dont want to screw anything up
Help2
lol
Yes, Im positive.
You think the air can tell the difference?
I mean, aesthetically, Id use a slot port
because of the shape of the subs..
But it doesnt matter.
Norman, Oklahom
Post Number: 7
thanks alot man, hey, i've heard that solobaric L7's have a tendancy to juss fail and blow for no reason. is this true or are these people who are sayin it juss hatas? cause i juss bought a solobaric s12L7
Help2
It is true.
Then again I know people who throw
3000 watts a piece on em for comps and dont have problems.
Depends on the install and the surrounding equipement, and how you treat it.
Username: Coxy_2k5
Ohio
i have 2 L5's, will a jl 500.1 amp be powerful enough to run these subs with enough power to make them hit hard?
Norman, Oklahom
Post Number: 8
yeah man, juss make sure you put em in a ported box cause that will like double your bass response in the area of SPL sound pressure level. the decibles but yes the amp should be juss fine cause you can put like 250 watts to each if you split the power and i know a kid with one L7 and he pushes like 300 watts to only one of his in a ported box and that thing is as loud as you will ever ever need it, you can hear the biotch from like a block away
Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Square port or circle [ « Previous ] [ Next » ]
