Thread: Kicker or memphis amp for shiva |
Bronze Member Username: 50amps
Ontario
Post Number: 30 Registered: Sep-04
| Posted on Sunday, November 14, 2004 - 05:58 pm: |
I know there is quite a lot of info on here about the shiva but i was hoping i could get some info that deals with my setup in particular. My question is would it be better to get the kicker kx600.1 (600 watts) or the memphis mc500 D (500 watts) to power 2 shivas. They would be in larger ported boxes (around 3.5 cubes each) tuned to 24 hz. Would the shivas be able to reach close to full excursion in this larger box with 250 watts each or would it be neccessary to get the kicker which has 300 watts plus? Thanks
New member Username: Kickerlover88
Norman,
Oklahom
Post Number: 3 Registered: Nov-04
| Posted on Sunday, November 14, 2004 - 08:43 pm: |
go with the kicker man, they are juss a good amp and you can always adjust the gain so you wont have to worry about blowin em nice day to ya |
Ontario
Post Number: 32 Registered: Sep-04
| Posted on Sunday, November 14, 2004 - 10:28 pm: |
thanks for the opinion. does anyone else have one about this matter? |
Ontario
Post Number: 33 Registered: Sep-04
| Posted on Sunday, November 14, 2004 - 10:50 pm: |
glass i know your busy but could u offer your opinion on this? i can't afford to waste any money. |
Bronze Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 48 Registered: Oct-04
| Posted on Monday, November 15, 2004 - 02:55 am: |
Kicker amps are nice and usually under rated. So it will probably put out more like 650-700 watts. set the gain properly and you should be fine. Memphis is good stuff too, but if you can get a more powerful kicker amp for the same price then do it, you won't be disappointed. |
Ontario
Post Number: 35 Registered: Sep-04
| Posted on Monday, November 15, 2004 - 12:04 pm: |
okay thanks for the help |
Ontario
Post Number: 36 Registered: Sep-04
| Posted on Tuesday, November 16, 2004 - 12:41 am: |
If it is not going to come close to maximizing the potential of the shivas than I will get the kicker. The kicker amp is actually going to be about 80 dollars more so I was wondering if I could get away with using the memphis? Thanks guys |
