Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > Jeep GCH'99 Infinity Gold system ques...
Author Thread: Jeep GCH'99 Infinity Gold system question
Username: Otash
Does anybody know what size and kind of speakers do i have? I am going to replace all 6 speakers, so what kind and size would be the best?
Username: Glasswolf
NorthWest, Michigan
Post Number: 5737
what is it? a 1999 grand cherokee?
WJ body?
Username: Otash
Post Number: 7
yes it is Grand Cherokee Laredo
what is WJ?
here the body on picUpload
Username: Glasswolf
NorthWest, Michigan
Post Number: 5756
your model of jeep. it's a "WJ" body
prior to 99, they were the "ZJ" body
you have 6x9" factory speakers front and rear.
with an adapter or a plate, you can stick 6.5" separates in there just as easily.
How do you like that 99?
I have a '94 Laredo 5 speed, and I'm going this week to look at a fully loaded '01 JGC Ltd.
Username: Otash
Post Number: 8
how about the front ones, tweeters?
Username: Glasswolf
NorthWest, Michigan
Post Number: 5778
front doors are 6x9.
tweeters you could cram up to a 3" in there, but tweeters from separates fit well.
Username: Sosaoso
I also have a 99 GC WJ body. How do I pick and choose between all the brands for tweeters? Should I stay away from one or the other? I'd like something decent but I don't need top of the line.
From what I've read online, those stock infinity tweeters Jeep put in have blown for alot of folks including me.
Username: Otash
Post Number: 9
i've got one blown too.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5847
Infinity Kappa Perfect 6.1
it's a 6.5" separate system with mids, tweeters, and crossovers.
fits in the factory locations easily, and runs $200 new on ebay for the set.
Username: Otash
Post Number: 11
is there any chance to get factory speakers?
and if yes then where?
Username: Sosaoso
A guy at my local audio place gave me a few options. For tweeters he said a good base set are the Memphis PR at 59.00 a pair or if my front door speakers are bad the the Alpine 6 and 1/2 type s component system. Thats two tweeters, two door speakers and a crossover for the wires all for 179.00 plus another 40.00 to install.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > Jeep GCH'99 Infinity Gold system ques... [ « Previous ] [ Next » ]
