Thread: Kick Panel Enclosures HELP!!! |
Bronze Member Username: Therainman
Post Number: 17 Registered: Oct-04
| Posted on Saturday, November 13, 2004 - 02:57 pm: |
Is there any other source then Q-logic for these panels? i need one for my 1991 s10 ext cab. I dont like the 129 dollar price tag seems kinda much and i dont really see the product really costing the make it. SO is there any other brands sites etc? could you provide a name or link and price if so? |
NorthWest,
Michigan
Post Number: 5726 Registered: Dec-03
| Posted on Saturday, November 13, 2004 - 04:21 pm: |
Qforms are about it for kick pods. $129 isn't too bad honestly, once ya see them. they're very well made. The other option is to fiberglass your own pods, but you'll end up spending just as much to do it yourself, between shaping foam, fiberglass, resin, gelcoat to color match the pods, etc.. This isn't a cheap hobby to get into, if you want something decent in the end. I wish there was a better answer to offer. I know a place or two that'll do pods made to order, but you'll spend even more from them.
