Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Jeep GCH'99 amp installation
Author Thread: Jeep GCH'99 amp installation
Username: Otash
does any body know how to hook up new amp without taking off factory(infinity gold)? Do i hook it up to factory amp or to player?
I have a mono amp that will be used only for subwoofer.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5712
you get a Metra adapter harness that taps into teh factory system and gives you a set of RCA pre-outs to use for the amplifier.
That's the only good way to do it.
www.metra-online.com
Username: Otash
where do i hook it up? to player or to factory amp? can u give me the full name of this adapter?
Username: Otash
is it Metra Amplifier Integration Wiring Harness Adapter?
Username: Glasswolf
NorthWest, Michigan
Post Number: 5731
yes
Username: Otash
where can i find it?
everywhere i look it is for ford models.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5738
any car audio shop should be able to order one or have it in stock.
you could try through metra-online or partsexpress.com or similar as well.
Help2
Is that a LOC or something...
never heard of the metra.
A LOC will work most likely too.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5746
Help2, the Jeep's premium system is similar to the Bose and Mach systems. It uses amplifiers in the stock system, so a line reducer is required to get a clean line level signal. there is a harness sold that splits off the factory amp harness to provide the proper RCA line outs for adding an amplifier and subs to the factory system.
Username: Otash
Post Number: 10
does anybody know what kind of amp do i need for pioneer sub (450 w max, 150 nom)? does sony XPLOD XM-2100GTX(600 Watts 2 channels max
100 watts RMS x 2 at 4 ohms
125 watts RMS x 2 at 2 ohms
250 watts RMS x 1 at 4 ohms
stereo 2 channel or bridged mono 1 channel output
4-ohm stable in bridged mode
Tri-way capable
MosFET power supply
low-pass crossover
preamp and speaker level inputs
preamp outputs
variable bass boost (0-10 dB) centered at 40 Hz)
go okay with it?
Username: Otash
Post Number: 12
and what would be the remote wire from amp be connected to? does my system has an out for it?
Home > Message Board > Car Audio > Amplifiers > Archive through November 19, 2004 > Jeep GCH'99 amp installation [ « Previous ] [ Next » ]
