Thread: Help Glasswolf! |
Bronze Member Username: Bumpingloud
Phoenix,
AZ
Post Number: 15 Registered: Oct-04
| Posted on Friday, November 12, 2004 - 10:02 pm: |
i have a jbl 1200.1 I was Thinkin About Buying two kicker 15 inch Comp Vr15 Dual 4ohm. 500rms each I was Wondering What Kind Of Box should i get I mostly listen to rap music I want it to hit deep and low. Also Are 12inch better than 15 inch subs Thanks. |
NorthWest,
Michigan
Post Number: 5695 Registered: Dec-03
| Posted on Friday, November 12, 2004 - 10:09 pm: |
12 or 15 are up to you. I'd go ported, tuned to around 34Hz for a 12" and 28Hz for a 15" if it were me..
Phoenix,
AZ
Post Number: 16 Registered: Oct-04
| Posted on Friday, November 12, 2004 - 10:16 pm: |
So 12 inch sound pretty much the same as 15 huh. So Im Making a good decision right? |
NorthWest,
Michigan
Post Number: 5698 Registered: Dec-03
| Posted on Friday, November 12, 2004 - 10:20 pm: |
they won't sound the same.. but which yu prefer is subjective I prefer 12" myself. many prefer a 15" audition both and see which you like a pair of 15" would be better suited to rap and overwhelming bass. I feel I have a bit more control and accuracy using 12" subs, without giving up the low resonant bass.
New member Username: 54danny54
Post Number: 7 Registered: Nov-04
| Posted on Saturday, November 13, 2004 - 12:26 am: |
If ur stuck between 12 and 15's then buy1 of each...test thier sound...pick 1...sell the othe and buy the 1 u liked
Bronze Member Username: Thrust
Post Number: 33 Registered: Nov-04
| Posted on Saturday, November 13, 2004 - 04:01 am: |
15's would reproduce lower frequencies. Definitely ported for rap lover. ported = boomier, sealed = sound Q |
