Thread: How will this sound? |
New member Username: Dustin507
Post Number: 1 Registered: Nov-04
| Posted on Friday, November 12, 2004 - 08:22 pm: |
I recently purchased two 12" R-types from a friend who decided to upgrade to the type-x. I will be honest, I have little to no money to spend on this, so i opted with a Boss 1400w amp that puts out 300x2 rms. could someone tell me what kind of result they think this will produce, I know Boss products aren't the best. Also, one of my friends said I should go with 8 guage wiring, the other said 1 guage, which should I go with? Thanks for any help you can give. |
| Posted on Friday, November 12, 2004 - 08:33 pm: |
You should go with 4 awg wiring What kind of box will you be putting the subs in? |
Post Number: 2 Registered: Nov-04
| Posted on Friday, November 12, 2004 - 08:37 pm: |
I am not sure about any specifications on the box, I bought the subs in the box he had then in, which he said was custom made. All i know is that it is a sealed one. |
Post Number: 3 Registered: Nov-04
| Posted on Friday, November 12, 2004 - 08:56 pm: |
so can anyone tell me how they think this setup will sound? |
NorthWest,
Michigan
Post Number: 5691 Registered: Dec-03
| Posted on Friday, November 12, 2004 - 09:53 pm: |
for a 600 watt amp, use 4ga cable from the battery. it should sound good. those subs are ideal with about 300 watts each
Bronze Member Username: Thrust
Post Number: 28 Registered: Nov-04
| Posted on Saturday, November 13, 2004 - 03:12 am: |
will sound fine yo |
