Thread: 2-Channel Amp? |
Bronze Member Username: Rds11
Louisville,
Kentucky
Post Number: 22 Registered: Nov-04
| Posted on Friday, November 12, 2004 - 10:53 am: |
could I use a 2-channel amp to power my 4 (coaxial or Comp)speakers inside my car? like if i wired each channel in parallel to show a 2-ohm load then would that be fine. Would I lose and SQ and would I need to make sure that every speaker was the same or at least the two on each channel? Help plz. Im prob gettin a Orion H2 in a vented box so i need to maintain some good SQ to hear the words. |
NorthWest,
Michigan
Post Number: 5676 Registered: Dec-03
| Posted on Friday, November 12, 2004 - 11:21 am: |
you can do this. you just lose the ability to fade between front and rear speakers since both are wired together in parallel. the only problem with this is without the use of l-pads, you may get too much from the rear speakers, which can mess up your sound stage.
Bronze Member Username: Thrust
Post Number: 18 Registered: Nov-04
| Posted on Friday, November 12, 2004 - 12:31 pm: |
you could put all 4 of those speakers up front (kick panel & door)and have no rear fill or use the rear speaker outs from the headunit for rear fill |
Silver Member Username: Carguy
Post Number: 197 Registered: Nov-04
| Posted on Friday, November 12, 2004 - 12:39 pm: |
Whoa, isn't it easier to just get 4 channel amp? |
| Posted on Friday, November 12, 2004 - 02:48 pm: |
It is easier to get a 4 channel amp, yes. Honestly, Id forget about the back coaxials and just run the fronts from a smaller 2 channel amp.
