Home > Message Board > Car Audio > Amplifiers > Archive through November 14, 2004 > Amp and speaker wiring
Author Thread: Amp and speaker wiring
Username: Hurleyblink187
Post Number: 7
umm im about to purchase a Audiobahn AW120T sub, along with a sounstorm 500x2 amp, just a question, when i go to bridge the channels doesnt that give me a 2ohm impendance. or it doesnt matter as long as you have the sub wired at 4 ohm, the Audiobahn AW120T is single 4-0hm voice coil. just wanted to make sure this would work out before i bought this.
Help2
First of all, I wouldnt recommend either of those
products.
If its because youre low on cash, i can understand that, buy you should think a little more
before you buy that stuff.
as far as the wiring is concerned.
"bridging" and amp is connecting 2 2ohm channels
in parallel.
But your amp only acts on the resistence
it "sees"
a single 4 ohm speaker will draw 4 ohms from
a bridged amp, yes sir.
Home > Message Board > Car Audio > Amplifiers > Archive through November 14, 2004 > Amp and speaker wiring [ « Previous ] [ Next » ]
