Home > Message Board > Car Audio > Amplifiers > Archive through November 14, 2004 > Alpine MRV F540 4-channel?
Author Thread: Alpine MRV F540 4-channel?
Username: Yinyang
CA
Post Number: 14
What do you guys think about the Alpine MRV F540 4-channel amplifier for Infinity Perfects 6.1 & 5.1 comps? Also, how can I get the most power out of this amp using a standard 12V battery? I'm thinking about getting it.
Username: Yinyang
CA
Post Number: 15
Or, what else would be good or better choice of an amp? thanks
Username: Thrust
Post Number: 11
Alpine makes good stuff PERIOD. The setup you described (as long as the watts match up) would prob sound PD good! I'm currently about to test drive some PPI DCX 650S's. Usually your openings in whatever car you have determine what size speaker you buy. I personally prefer 6 1/2's over 5 1/4's(lower bass response).
Home > Message Board > Car Audio > Amplifiers > Archive through November 14, 2004 > Alpine MRV F540 4-channel? [ « Previous ] [ Next » ]
