Thread: Need help to hook up amp with speaker |
New member Username: Exoticlov3r
Post Number: 1 Registered: Nov-04
| Posted on Thursday, November 11, 2004 - 05:14 am: |
Hello everyone. Anyone know how to hook up sony xm222w 2channel to 2 6 1/2 front speaker and 2 6x9 rear speaker. The instruction i had was lil confuse so i need some help yall. Thank u very much |
Silver Member Username: Carguy
Post Number: 177 Registered: Nov-04
| Posted on Thursday, November 11, 2004 - 10:02 am: |
Hey Cu Bu, that Sony amp sucks first of all and it's only a 2 channel. You can either connect it to the front or rear speakers. If you want to power all of them, then get 4 channel amp. If you HU has rca connectors, use that, if not get speaker level to rca converter. |
New member Username: Thrust
Post Number: 8 Registered: Nov-04
| Posted on Thursday, November 11, 2004 - 12:25 pm: |
If that amp is 2 ohm stable you can hook up left (front & rear) to one channel and right (front & rear) to the other channel. Won't be able to fade front to rear, but hey, they will "all be hooked up". |
Post Number: 179 Registered: Nov-04
| Posted on Thursday, November 11, 2004 - 02:00 pm: |
Whoa, well could do that but would it be worth the time and effort?
here'sjonny Unregistered guest |
| Posted on Thursday, November 11, 2004 - 10:05 pm: |
if the speakers are 2 ohm stable and so is the amp, you could hook up the front left and rear left... in parallel. This, however, would take a lot of speaker wire and wouldnt be optimal. Your best bet if you can spare the cash is to pick up a four channel amp. To hook the speakers in parallel, run a 2 wires from each channel to the rear two speakers, then run another wire from the speakers to the corresponding +/- on the front speakers. Wire left with left and right with right. Make sure the amp and speakers are two ohm stable or you'll be out a few bucks. the speakers probably are not. |
