Thread: HELP with IDEAS!!!buying soon |
New member Username: Dev
Poo vill,
Bc
Post Number: 5 Registered: Nov-04
| Posted on Wednesday, November 10, 2004 - 07:17 pm: |
kay , i am building a system , i have 1100$ 2 spend on subs , and im willing 2 spend around 2 grand on an amp.im new 2 all this stuff so im not sure wat would work with wat good,i have a 98 eclipse so it has to fit in the trunk.I am intrested in the alpine Type X 12",but im really not to sure wat amp would work well with them , they have apeak power of 3000 watts-power range 500-1,000 watts RMS (500 watts per coil)im guessing im gona need 2, 1000 wat amps , should i get alpine amps and if so , wat kind , i know im asking alot but i dont want to make regreat anything i do and im just looking for a good performanc system thats not gona let me down,thanks for the help |
Silver Member Username: Carguy
Post Number: 162 Registered: Nov-04
| Posted on Wednesday, November 10, 2004 - 09:34 pm: |
Hey James, slow down a bit. Before you fork over couple of grand, do some research. If you have the cash, here's a good amp for it. ROCKFORD FOSGATE POWER T30001BD, it's rated 1000W @ 4ohms, 2000W @ 2ohms, and 3000W @ 1ohms. This is all RMS power not peak garbage. If you have a car stereo store, visit one and ask for a demo. If I ever get rich, I'd like to buy this amp and review it. Till them I'm testing Audiobahn A4125HCT. BTW, have you seen MA Audio's subs? I have 18" and it really pounds. It's magnet is over 20 lbs!
| Posted on Thursday, November 11, 2004 - 10:24 pm: |
infinity kappa perfects are awesome subs. If you really want the best though, JL W7 is the best I've ever heard. They are real pricey. Around 500 I think for a 13 inch. The infinity's are 150 apiece and I think two or more would be better than 1 w7. I think it's ridiculous that anyone would spend more than 1500 for sub and amps together. but if you want the best spend the extra and get JL products. |
NorthWest,
Michigan
Post Number: 5663 Registered: Dec-03
| Posted on Thursday, November 11, 2004 - 10:43 pm: |
start with a good source and front components example, Eclipse CD8454 ($600) CDT Classic CL-61 separates ($250) 4 channel amp.. try something like a Zapco Reference 4 channel amp then an amplifier such as that RF Isaac mentioned, or an Orion class D amp for teh two Type X subs. after that, you'll want to beef up your charging system a bit, and perhaps add rear fill speakers if you feel the need for them.
