Thread: Help with wiring please. |
Silver Member Username: Jonez788
Post Number: 111 Registered: Jun-04
| Posted on Wednesday, November 10, 2004 - 06:54 pm: |
I have two single coil 4 ohm subs. I need them to work with an amp with these specs. 110 watts x 2 ch rms output power (2 ohms) 220 watts bridged rms output power (4 ohms) This is for a friend please help. How do I have to wire them to work? |
| Posted on Wednesday, November 10, 2004 - 07:50 pm: |
It wont work man. You could either wire them at 8 ohms bridged(parallel) or 2 ohms bridged(series) neither of which is good. It will sound better to hook just one sub up. Or to get an amp thats 2 ohm stable (mono)
Silver Member Username: Carguy
Post Number: 184 Registered: Nov-04
| Posted on Thursday, November 11, 2004 - 02:53 pm: |
Hey Jonez, you should be able to find a used amp on eBay that'll more than drive those speakers at a low price. If your on a tight budget, you could try and run the bridged amp in 2 ohms mode. Just don't crank it up to the max. I do that with my current sub amp. Works just fine. Better choice would be to have an amp that supports 2 ohms bridged. |
| Posted on Thursday, November 11, 2004 - 03:49 pm: |
Running a 4 ohm stable amp at 2 ohms will substantially shorten its life. It may work fine for a while. until you let the smoke out of it of course. |
Post Number: 185 Registered: Nov-04
| Posted on Thursday, November 11, 2004 - 10:49 pm: |
Hey my amp runs warm cause I installed my own custom made fan. It used to shut down at 2ohms, now it just pumps bass. I'll give you a clue, buy a quiet computer cpu fan and install it on the amp. Does wonders. |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 216 Registered: May-04
| Posted on Friday, November 12, 2004 - 01:34 am: |
if the amp is designed for a certain load dont go under itevene at high or low volume you might get to a bass drop and there goes your amp. Just get an amp that can handke the load that you want. |
