Home > Message Board > Car Audio > Amplifiers > Archive through November 14, 2004 > Amp problems
Author Thread: Amp problems
Username: Xxkmfdmxx
Post Number: 38
Recently I tried installing two different amps. One Pyramid and on MA audio one..Yeah I know, crappy brands, But I have a pyramid sub that sounds decent so I figure I'd try their amp. Anyway, When I tried hooking up the Pyramid amp, everything went smoothly but it actually sounded better WITHOUT the amp, same as with the MA audio one. Could it be just because they are two not so good companies or something else?
Username: Carguy
Post Number: 134
Hey mdfmk, Pyramid do not make good amps, MA Audio however does on certain models. If you go for their cheap ones, then yes, they suck.
If the amps were connected properly, it's suppose to sound better. Have you set up the gain/level according to your HU?
Also if you use the speaker wire converter, it'll degrade the sound quality. RCA is a better choice.
Username: Xxkmfdmxx
Post Number: 39
The levels were set up correctly and I did use RCA. still no luck with it sounding better.
Username: Carguy
Post Number: 137
Ok then explain what you mean by not sounding better. Are you comparing it to the HU? Is it poor quality at high volumes or at all settings? Does the mid and highs distort or just the lows on the subs?
Username: Xxkmfdmxx
Post Number: 41
Yeah I'm comparing it to the HU. With the amp it Distorts at low volumes(which would also be poor quality at high volumes)
Username: Carguy
Post Number: 139
When you say it distorts, do you mean the sound shakes or is choppy?
If you had proper equipments, you could measure the output of the amp and see if it's bad.
Most likely, the cause could be from either inadequate power or poor signal shielding. Is your ground any good? Sometimes that can be the problem.
Username: Xxkmfdmxx
Post Number: 42
Basically sounds choppy, What kind of equipment is needed? I might have it. I have the ground wire grounding to a peice of metal underneath the dash, Is that good enough?
Username: Carguy
Post Number: 142
Whoa did you say you have a ground wire underneath the dash? Where is your amp located? People usually install them in the truck and create a new grounding there by sanding a piece of the metal sheeting.
If you're into electronics, you should be able to measure the output with a scope and determine the distortion factor. You'll also need a signal generator for the input.
Username: Xxkmfdmxx
Post Number: 43
I have the amp in the glove compartment. Didn't have long enough wires at the time to mount it somewhere in the back so put it there instead. Only temporarily. I'll measure the output later on today though and get back to you.
Username: Carguy
Post Number: 154
Whoa, you either have a big glove compartment or a small amp. Grounding is very important. It has to be done right or else you'll pick up noise and have weird problems.
Username: Xxkmfdmxx
Post Number: 45
Well The amp wasn't that big, Not a bad size though. What would you reccomend grounding it on instead?
Username: Carguy
Post Number: 161
If you take a look at your battery, it's already grounded. Why don't you borrow that to test the amp? Just make sure all the dirt/rust is sanded off.
Username: Xxkmfdmxx
Post Number: 46
So test the amp directly on the battery? Just bought the battery two days ago so no need to sand =P
Username: Carguy
Post Number: 163
No I meant use the ground wire the battery is connected to. It should provide a good base for testing your amp.
Username: Xxkmfdmxx
Post Number: 47
Hmm ok, I think I know what your talking about now. I'll test it tomorrow and post.
Thanks for your help by the way.
Username: Xxkmfdmxx
Post Number: 48
Just got done hooking it up again, sounds better. Thanks!
Username: Carguy
Post Number: 178
Glad it worked out for you.
Home > Message Board > Car Audio > Amplifiers > Archive through November 14, 2004 > Amp problems [ « Previous ] [ Next » ]
