Thread: Glasswolf opinion please! |
kklagge Unregistered guest |
| Posted on Tuesday, November 09, 2004 - 10:56 am: |
How do you feel about Image Dynamics components & subs? |
Bronze Member Username: Xxkmfdmxx
Post Number: 36 Registered: Oct-04
| Posted on Tuesday, November 09, 2004 - 01:43 pm: |
I think their pretty good. What glass thinks, I don't know. |
| Posted on Tuesday, November 09, 2004 - 01:51 pm: |
Yes, ID is good. I used to have the 2 ohm Chameleon comps. I was very happy. |
| Posted on Tuesday, November 09, 2004 - 02:06 pm: |
The 2ohm comps are the ones I'm looking to get. Do they handle the power they claim? |
| Posted on Tuesday, November 09, 2004 - 02:32 pm: |
I had them on an Arc 1500D-R for over a year. They sounded great. I wouldnt recommend that much power normally. They can handle 150wRMS with grace.
| Posted on Tuesday, November 09, 2004 - 02:56 pm: |
Thanks for the info! |
NorthWest,
Michigan
Post Number: 5622 Registered: Dec-03
| Posted on Tuesday, November 09, 2004 - 03:49 pm: |
yeah ID makes some really sweet stuff. I believe they used to make some compression horns that were pretty cool, too. IDmax subs are great. the components you're looking at are very good, too.
