Thread: Old amp...no remote wire? |
Matty00pro Unregistered guest |
| Posted on Tuesday, November 09, 2004 - 08:34 am: |
I just got this amp (Pioneer GM-2000) but it doesn't have a remote wire spot, just wondering how to hook it up. |
Bronze Member Username: Carguy
Post Number: 96 Registered: Nov-04
| Posted on Tuesday, November 09, 2004 - 09:05 am: |
You might have to buy a remote wire kit then. Without remote wire, you'll have to manually turn on and off the amp. It's not a good idea. If the amp is not worth much, you might want to invest in a bit more modern one.
| Posted on Tuesday, November 09, 2004 - 10:58 pm: |
So just put a switch on the power cord? Is that bad for the amp or battery? How were they hooked up in the past/when they came out? |
Silver Member Username: Carguy
Post Number: 122 Registered: Nov-04
| Posted on Tuesday, November 09, 2004 - 11:31 pm: |
I wouldn't recommend it. You see if you forget to turn off the amp manually, you'll drain the battery. Best way is to either buy a new amp (easiest) or by the remote wiring kit. The ladder will reqire some skills. Besides, I don't think you'll be able to find a power switch that's 60A rated.
| Posted on Wednesday, November 10, 2004 - 02:17 pm: |
Can't just splice the switch with something.....like ignition, or headlights. So when the driving lights are turned on, the amp is turned on also? (& off when lights off) If i have another amp already hooked up, can i somehow just feed from it's remote on/off signal? Sorry for all q's, just wondering before i jus get new amp. |
Post Number: 153 Registered: Nov-04
| Posted on Wednesday, November 10, 2004 - 02:49 pm: |
Hey Matty, just remember, other devices are low amperage. Your head lights for example might have a 30A fuse. The amp is usually 60A. You'll most likely bow the fuse for lights, heater etc. If you have any experience in wiring cars, buy a remote wire kit and link it to ignition switch. Unless the old amp is worth all this trouble, I'd get a new amp.
