Thread: Alpine MRD-M501 vs Boss IQ3KD.1 or Boss RIPD3 |
Unregistered guest |
| Posted on Tuesday, November 09, 2004 - 12:55 am: |
Hi all, I am looking for advice on these amps, I have the opportunity to pick up each one at about the same price and I am not sure what to do. I am a long time Alpine fan, but I am not sure that the smaller Alpine would be as good as the larger Boss amps. I want to drive 2 12" Audiopipe subs that are 800 watts RMS a piece. I am aware that the Alpine will probably outlast the others but will it drive the subs better? Any other suggestions will be welcome aswell within that price range. Cheers Glenn |
NorthWest,
Michigan
Post Number: 5605 Registered: Dec-03
| Posted on Tuesday, November 09, 2004 - 10:21 am: |
the alpine is far better quality than anything boss ever made
Silver Member Username: Carguy
Post Number: 140 Registered: Nov-04
| Posted on Wednesday, November 10, 2004 - 10:54 am: |
FYI, BOSS does make a model that actually works at a lower price. But I agree with GlassWolf, Alpine is your first choice.
Terminatermule Unregistered guest |
| Posted on Wednesday, November 10, 2004 - 07:47 pm: |
ta fellas, i have settled on less power and better quality but have posted another q asking if that alpine would be enough to push 2 12' subs, your views would be appreciated. Cheers |
| Posted on Wednesday, November 10, 2004 - 08:02 pm: |
iirc it does 450 @ 2 ohms... That would be ok for 2 12's with low RMS, sure
| Posted on Wednesday, November 10, 2004 - 08:17 pm: |
cool ta - then i will have to look else where as the subs are 2 by 800 watts RMS, I don't want to drive them flat out but enough to have nice bass with room to spare if i decide i want more Cheers |
| Posted on Wednesday, November 10, 2004 - 08:30 pm: |
Put whatever subs your thinking about up here, and well get you sorted out  |
| Posted on Wednesday, November 10, 2004 - 09:34 pm: |
I am looking at a pair of Audiopipe 12" subs, they claim 800 watts RMS each and have dual 2 Ohm voice coils, i checked with their agent and he confirmed that they are dual 2 Ohm so 1 Ohm in parrel operation, I have heard good things about the audio pipe subs and i am on a limited budget so they looked like a good thing, but I am thinking that perhaps I should get a pair of something more respected but lower powered. Any advice would be great, in case you are wondering what my deal is with the odd brand choice, I have nothing against RF or any of the other brand popular here, but I live in Aus and some of these brands are hard to find and if you do they are very expensive Cheers |
