Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > Best Component Speaker System For Bass?
Author Thread: Best Component Speaker System For Bass?
Camron Newell
I was wondering what the best component 6.5" system will provide the most bass. Under 400$ preferrably! Thanks
Username: Glasswolf
NorthWest, Michigan
Post Number: 5589
none.
they aren't made to produce bass.
that's what subs are for.
Username: Blownriv
OH
Post Number: 40
diamond audio HEX, JL audio ZR/XR/VR, & adhire koda all have woofers with decent xmax specs. they should be solid into the 60Hz range with a steep hi-pass filter at around 70-80Hz. below that, you need a sub.
components are intended to produce some bass, just not the low stuff (60Hz and down).
Username: Glasswolf
NorthWest, Michigan
Post Number: 5610
at 60Hz they're going to be down about 12dB or more, which is pretty pointless. it's nothing you're really going to "feel" for under $200.
If you want to feel MIDbass from components, use a 3-way set like the DynAudio System 360 with it's 8" midbass driver.. but those need a solid 200wRMS/channel and they're about $1200/set
Also, they eat up a lot of space for mounting just due to the 8" midbass, 4" mid, and 1" tweeter on each side, plus the XO modules
Username: Glasswolf
NorthWest, Michigan
Post Number: 5611
oops, under $400 that is.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > Best Component Speaker System For Bass? [ « Previous ] [ Next » ]
