Thread: Reducing output on one set of speakers |
proxybox Unregistered guest |
| Posted on Monday, November 08, 2004 - 07:09 pm: |
Hi, I have a four channel amp that feeds front and rear speakers. What is the best way to reduce the output to the rear speakers. I have read that I could use an L-pad to passively reduce the output and have some control. Are there any other methods that I am not aware of? Thanks, jon los angeles |
NorthWest,
Michigan
Post Number: 5587 Registered: Dec-03
| Posted on Monday, November 08, 2004 - 07:22 pm: |
yes. it's called the "fader" on your head unit.
| Posted on Monday, November 08, 2004 - 09:20 pm: |
The fader will not work since I have the four speakers connected to the single amp. I used the other low level output to another amp which drives the subwoofer. Therefore, the fader will only switch between the four speakers and the sub. I need a way to reduce the output on the rear deck speakers to balance the staging. jon |
Bronze Member Username: Ps1k0
Post Number: 47 Registered: Aug-04
| Posted on Tuesday, November 09, 2004 - 12:49 am: |
so you should have two sets of gains, one set for front and one for rear. turn the rear ones down. |
NorthWest,
Michigan
Post Number: 5609 Registered: Dec-03
| Posted on Tuesday, November 09, 2004 - 10:30 am: |
use an external electronic crossover with level control, like audiocontrol's 6XS, or the Coustic XM3, or get a head unit with 3 sets of pre-outs F/R/S
