Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004
  Thread Last Poster Posts Pages Last Post
Polk Momo MM12 Sub. Any Recommended Amps?Fosgate Monster Audi2004-11-05  10:59 ET
Power for my subsIsaac2004-11-04  09:54 ET
Will this cause clippingGlassWolf2004-11-04  09:38 ET
Best subs for my ...ALPHASONIC PMA 2300Jonathan2004-11-03  23:25 ET
Quick RMS questionJonathan2004-11-03  23:18 ET
What amp do you guys think?Isaac2004-11-03  22:53 ET
Best amp for this sub? ( 15" kicker l5)Paul Harrison2004-11-03  22:03 ET
Some easy help pleaseIsaac10 2004-11-03  22:01 ET
Ok everyone i know what i want, now i need help wiring it.Arrin Patterson2004-11-03  17:26 ET
Confusing amp situation. Can't figure it out.Isaac2004-11-03  17:10 ET
Confused About Amps!GlassWolf65 2004-11-03  17:09 ET
Amp for shivaGlassWolf2004-11-03  13:29 ET
Amp for rockford fosgateBadAzzBowtie2004-11-03  13:20 ET
Advice: Do I need A new HO Alt and/or Battery?Damien Roberts2004-11-03  10:12 ET
Where to get Diamond Audio items fromJDC2004-11-03  09:53 ET
Are Planet Audio amps any good???(the 1250.1)GlassWolf2004-11-03  08:13 ET
Rockford Fosgate Punch P8002Jonathan2004-11-03  02:07 ET
Seems the Sub is running a bit quietJonathan2004-11-03  00:55 ET
So much bass that i cant hear the treble of my music....Joseph2004-11-02  23:28 ET
Proper amp for component speakers?Aaron2004-11-02  23:17 ET
Need to know about amp for Kicker 15" comp subJoseph2004-11-02  23:08 ET
Im Stumped, Please helpArrin Patterson2004-11-02  21:05 ET
Help choose amp...Travis Hogg2004-11-02  20:51 ET
Where to buy JBL bp 1200.1 ?dat2004-11-02  18:34 ET
Fuse under the hood blew, please helpDamien Roberts14 2004-11-02  17:18 ET
Dont know what kind of amp to get for my subDamien Roberts2004-11-02  17:02 ET
Remote wire hook upDamien Roberts2004-11-02  16:58 ET
What is BFC ?GlassWolf2004-11-02  16:28 ET
Help with my system please!Isaac2004-11-02  15:54 ET
What amp should i get for 2 12" l7 solobarics?cavi9542004-11-02  15:52 ET
Whats better Subs threw mono or stereoIsaac2004-11-02  15:17 ET
Good place to get Diamond Audio?BlownRiv76 2004-11-02  01:18 ET
What Amp to Power This Sub? Steve2004-11-02  00:14 ET
Amp wont turn off unless fuse is outPat Lorenz2004-11-01  23:12 ET
Amplifier Information overloadGlassWolf2004-11-01  21:34 ET
Mono-block amp with 2 outputs???GlassWolf2004-11-01  21:33 ET
Is it requiered for a fuse under the hood for the amp wire?Damien Rob.2004-11-01  19:43 ET
Humming sound comming from amp while the deck is off, y?Anonymous2004-11-01  19:02 ET
How to install 2 subs into mono channel amp?Mark Payne2004-11-01  18:40 ET
Amp for audiobahn subsGlassWolf2004-11-01  15:52 ET
Phantom Amp?GlassWolf2004-11-01  15:50 ET
I need to shut pandora's box. A mix bag of questions.GlassWolf2004-11-01  15:47 ET
Which Alpine Amp for Perfect's 5.1 and 6.1 components?JTran2004-11-01  15:28 ET
Fuse ratingsGlassWolf2004-11-01  15:18 ET
WHAT SIZE AMP????GlassWolf2004-11-01  15:10 ET
My amp just suddenly diedryan12 2004-11-01  14:25 ET
Can i do this?James T. Kirk10 2004-10-31  21:44 ET
Just Bought Cadence amp and Kicker sub how do i wire them up?John De Groot2004-10-31  20:40 ET
Where can get a kicker XS100 amplifier!!!!!GlassWolf2004-10-31  20:38 ET
Amp for a kicker submark danes2004-10-31  20:38 ET
Types??james552004-10-31  18:05 ET
Wiring 3 JLw3 dual 4 ohms for a mtx thunder81000dAINTnoLOVE2004-10-31  16:09 ET
Amp DiedAnonymous2004-10-31  14:31 ET
Confused on the wiring on my amp, can anyone help?Maurice Ouellette2004-10-31  13:56 ET
Mtx421d good?GlassWolf2004-10-30  23:27 ET
What amp should i get for these?GlassWolf2004-10-30  23:25 ET
Experimental amplifier: Input neededGlassWolf2004-10-30  23:22 ET
Would anyone recomend the Boss iQ 680.2 Ryan Tilton2004-10-30  22:25 ET
Mobile Authority Ampsxxmdfmkxx2004-10-30  18:30 ET
Wiring KitsSkeeter2004-10-30  18:16 ET
Amp and Box for diamond M6's Eric772004-10-30  14:52 ET
Question every one likes i got close to a thousand dollars wat subs...Thales Santos2004-10-30  14:03 ET
Jonathan or Glasswolf or both??GlassWolf2004-10-30  12:11 ET
Question for glass on jbl 600.1 at 1 ohmBraddon Calloway2004-10-30  12:08 ET
DVCGlassWolf2004-10-30  11:58 ET
Running subs at 1 ohmGlassWolf2004-10-30  11:56 ET
Good mono amp for two 12"solo barics?sean2004-10-30  00:32 ET
4 channel Virtual reality ampmahanes2004-10-29  22:31 ET
Do I need to upgrade My alternator/Battery etc?GlassWolf2004-10-29  18:09 ET
Which amp? :-/Drtbker4life2004-10-29  17:32 ET
Which sub for this amp?Paul19862004-10-29  16:52 ET
Mono vs. 2-channel ampGlassWolf2004-10-29  14:14 ET
Wiring kitGlassWolf2004-10-29  14:03 ET
Is a JBL1200.1 overkill for 2 Kicker CVR12s?jeremie boop2004-10-29  13:04 ET
My setupGlassWolf2004-10-29  10:27 ET
Would this workGlassWolf2004-10-29  10:22 ET
GlasswolfGlassWolf2004-10-29  10:19 ET
1 jl w3GlassWolf2004-10-29  10:18 ET
How much WATTS does my amp need to be?GlassWolf2004-10-29  10:16 ET
900 dollarsIGOTIT4CHEAP2004-10-29  02:11 ET
2 channel and mono ampsDuane2004-10-29  01:26 ET
How much WATTS?Duane10 2004-10-29  01:20 ET
Alternator and battery questionGlassWolf2004-10-28  23:31 ET
RCA Interconnection CableGlassWolf2004-10-28  23:29 ET
NEED HELP iam in a jam!!!!...which amp?GlassWolf2004-10-28  22:48 ET
Diesel?????Elecgenius11 2004-10-28  20:48 ET
Please help amp for HX2please hellp2004-10-28  13:49 ET
Anybody got any opinions on bazooka?post your opinionsChris2004-10-28  11:55 ET
What should I set my phase shitft atGlassWolf2004-10-28  11:53 ET
Please post, what amp for my alpine subs *Help Please*GlassWolf2004-10-28  11:38 ET
Problem with jl 300/2GlassWolf2004-10-28  11:36 ET
EclipseGlassWolf2004-10-28  11:33 ET
I need to make a 4 ohm sub work on a 8ohm subGlassWolf2004-10-27  20:27 ET
What amp will power up two solo baric L5 12" kickersMillaLite2004-10-27  19:23 ET
How to install 2 subs into mono channel amp?Troy Bilodeau2004-10-27  19:19 ET
Amp for w6v2'sJosh Beck2004-10-27  17:09 ET
What does This mean?Chris2004-10-27  15:20 ET
Good amp for a rockford fosgate hx2dperi2004-10-27  14:11 ET
Rockford amp runnin a rockford Hx2dperi2004-10-27  13:39 ET
What Amp do I need?BadAzzBowtie2004-10-27  09:32 ET
Closed Closed: New threads not accepted on this page
Home > Message Board > Car Audio > Amplifiers > Archive through November 04, 2004 [ « Previous ] [ Next » ]
