Thread: Looking for an amp with 125W x 4 at 4 ohms! |
Bronze Member Username: Stamant
Pensacola,
FL
Post Number: 22 Registered: Sep-04
| Posted on Monday, November 08, 2004 - 06:36 pm: |
Anyone have some advice on a four channel amp pushing around 125W x 4 at 4 ohms? I was looking to spend around $200. Is this possible? Thanks. |
NorthWest,
Michigan
Post Number: 5582 Registered: Dec-03
| Posted on Monday, November 08, 2004 - 06:55 pm: |
Kicker KX800.4 is 100x4 @ 4 ohms, and its about $300 I think? Are you positive you need that much power for components? Zapco Reference series amps are around $350 and offer similar power, too. Also try MTX, like the Thunder404 or similar.
Pensacola,
FL
Post Number: 23 Registered: Sep-04
| Posted on Monday, November 08, 2004 - 07:08 pm: |
Glasswolf, No I'm not sure I need that much power. I have two 6.5" MB Quart component speakers and two 6.5" coaxials. I just want a clean, crisp, and powerful sound without hearing the speakers struggle for power. What do you think? thanks. |
Pensacola,
FL
Post Number: 24 Registered: Sep-04
| Posted on Monday, November 08, 2004 - 07:12 pm: |
Glasswolf, what would you use for the best sound quality in that price range? |
NorthWest,
Michigan
Post Number: 5586 Registered: Dec-03
| Posted on Monday, November 08, 2004 - 07:19 pm: |
if the kx800.4 is a bit steep look at the 600.4 its rated for 75x4 and should be plenty of power for the MBQ components far better than the 13x4 of the head unit
