Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2004 > Rca voltage
Author Thread: Rca voltage
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 25
I was thinking about getting a mtx 404 4 channel amp to run my door speakers. I read the pdf file @ mtx.com and it says 2.5v rms on the input. My deck has 5v outs. Will this damage the amplifier?
Username: Joe718
Brooklyn, NY
Post Number: 201
No it wont it will actually give you a cleaner signal.
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 28
I decided to go with the 564. Thanks for your input.
Username: Glasswolf
NorthWest, Michigan
Post Number: 5575
the MTX amp should take a range from 2.5 to 4 volts.
at most, you may slightly overdrive the input stage of the amplifier, but really, the RMS line voltage is usually a bit lower than the full 5 volts at normal levels, so its not an issue.
you'll be fine.
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2004 > Rca voltage [ « Previous ] [ Next » ]
