Thread: Decision time, help needed please |
New member Username: Mattyjoe
Niceville,
FL
United States
Post Number: 6 Registered: Nov-04
| Posted on Sunday, November 07, 2004 - 01:39 pm: |
which would you choose between these two pair of 12" subs: Rockford Fosgate HX2 RFD2212 PUNCH or AUDIOBAHN AW122T I believe they're both 500w RMS but im not sure which to pick. Also what would be a good mono amp to power them. Thanks alot to anyone who helps |
NorthWest,
Michigan
Post Number: 5553 Registered: Dec-03
| Posted on Sunday, November 07, 2004 - 02:04 pm: |
two 4 ohm (or dual 2 ohm coil) HX2 subs on any mono amp that delivers about 1000 watts RMS x 1 @ 2 ohms RF should offer at least one model that fits. I think the RF subs come in single 4 ohm coil versions
Niceville,
FL
United States
Post Number: 7 Registered: Nov-04
| Posted on Sunday, November 07, 2004 - 02:28 pm: |
for the HX2 it says Impendence 4ohm and Dual voice coils im looking at a Hifonics Brutus class D amp that is 500w @4ohm and 1000w @2ohm, would this be a good choice for the HX2's? (thanks again) |
NorthWest,
Michigan
Post Number: 5571 Registered: Dec-03
| Posted on Sunday, November 07, 2004 - 02:55 pm: |
the HX2 comes in tep versions. if both are dual coils, and offered as 2 or 4 ohm coils, get a pair of the dual 2 ohm coil models. this will give you an end result of a mono 2 ohm load, and your brutus will do fine.
